Conditional Feature Writing Based on Multiple Readers with ID Filtering
  • Oct 28, 2024 9:56 AM UTC
  • 6 replies
  • 155 views
jugoslaviaa
I have a workflow involving three readers (Reader 1, Reader 2, and Reader 3), and I need help setting up conditional logic based on feature counts for a given ID.
Here's what I'm trying to achieve:
  1. All three readers are filtered by the same ID.
  2. Condition 1:
    • If both Reader 1 and Reader 2 have at least one feature for the given ID, then do nothing—no features should be written to the writer.
  3. Condition 2:
    • If Reader 1 has at least one feature, but Reader 2 has zero features for the given ID, then:
      • Write the feature from Reader 3 that matches the given ID to the writer.
I'm looking for the best way to implement this logic in FME.
Thanks for any advice or examples!
Best answer by jugoslaviaa
@nielsgerrits
Thanks for the workbench! I need a bit of guidance on adjusting it for my specific requirements.
In my case, the ID is set as a user parameter, so all three readers (Reader 1, Reader 2, and Reader 3) will be filtered by this ID from the start. Sometimes, Reader 2 may have zero features simply because it doesn't contain any data with the specified ID and then I would like to copy the feature from Reader 3 with same id
nielsgerrits
Forum|alt.badge.img+67
One way to do this is to use a FeatureMerger to determine if a feature in 1 is also in 2. Then use that result and a second FeatureMerger to get all features from 3 that are in 1 but not in 2.
The first FeatureMerger can also be a ChangeDetector.
Sample attached.
jugoslaviaa
  • Oct 28, 2024 11:20 AM UTC
@nielsgerrits
nielsgerrits
I think you can connect these readers to the connections and they will just work?
jugoslaviaa
  • Oct 28, 2024 11:56 AM UTC
@nielsgerrits It does not work because one of the reads has no feature, so it won't be merged with a feature.
jugoslaviaa
  • Oct 28, 2024 12:15 PM UTC
@nielsgerrits I am very sorry. I messed up the port. It works!! Thanks a lot
nielsgerrits
Cheers :)
