concatenated parameters in python shutdown script not fully resolving
  • Jun 5, 2015 6:45 PM UTC
  • 42 views
jdh
Forum|alt.badge.img+41
I have a couple of published parameters param1, and param2 and a private param (param3) which is concatenated from the published parameter :  $(param1)-$(param2)
if param1 is A
and param2 is B
I'm expecting param3 to be A-B
instead, in the python shutdown script
fme.macroValues['param3'] returns A-$(param2)
any ideas on how to get it to fully resolved.
  • Jun 6, 2015 2:37 AM UTC
I'm not sure the reason that such unexpected result occurs, but this code could be used as a workaround for the interim.
value = '$(param3)'
Tested with FME 2015.1.0.2.
Takashi
  • Jun 8, 2015 9:02 AM UTC
Hi
can you show us the exact content (Python code) for the "param3" scripted parameter? Maybe screen capture?
David
jdh
  • Jun 8, 2015 2:21 PM UTC
Hi Takashi, That workaround did the trick. Thank you.
