Completely suppress logging
itay
Forum|alt.badge.img+17
Hi There,
I was wondering if anybody knows of a way to completely or partially suppress the logging in a workspace? (even if it is a hacky method)
I am aware of the settings in the options menu but unfortunatly they just don’t do the job necessary.
Cheers,
Itay
Best answer by david_r
Try the following in the Python startup script:
import fmeobjects
fmeobjects.FMELogFile().silent(True)
Testing with FME 2025.0 I only get the lines up until the startup script is executed, then only a single line at the end stating the the translation was successful.
Documentation: https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_log/fmeobjects.FMELogFile.silent.html
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • March 17, 2025
import fmeobjects
itay
  • March 17, 2025
Hi ​@david_r,
Thanks for the fast responce, this works in Form like a charm now….Is it possible to implement it in a linked transformer? 😉 (no startup script option there)
Cheers,
Itay
  • March 17, 2025
I guess you could put it in a PythonCaller, just be aware that it’s a global setting that will influence the entire workspace execution, and probably not just the linked transformer (not tested).
You can set .silent(False) to re-activate logging.
itay
  • March 17, 2025
HI ​@david_r
Unfortunately this does not work since the workspace is already initiated and therefore cannot be set to ‘silence’ the logfile. I don’t know if there is a way to do this at all, I will settled for encrypting the logfile but then again this might also prove to be beyond the current capabilities.
Itay
  • March 18, 2025
That sounds unexpected. My understanding is that you should be able to silence and un-silence the log at any point during the translation.
itay
  • March 18, 2025
Hi ​@david_r,
I would gladly be proven wrong :) this would be the best solution for me.
