Clip by GPs via Web interface:
  • Aug 18, 2013 2:19 PM UTC
  • 7 replies
  • 64 views
jhawks
Forum|alt.badge.img+7
I have a public web interface that is inteneded to allow users to extract shapefile data from Oracle SDE via GP key in. I have published parameters and created the interface but I dont know what transformers to use in the workbench to allow the GP clipping. Something about attribute filer I suspect.
http://fmeserver.ncd.noaa.gov/encdirect_extract_approach.html
  • Aug 19, 2013 10:18 AM UTC
I have difficulties understanding your question. Could you please tell what "GP clipping" means in this context?
David
jhawks
  • Aug 19, 2013 12:36 PM UTC
I want users to be able to key in Lat/Longs and extract data by that bounding box. GP extract probably makes more sense.
fmelizard
Forum|alt.badge.img+22
  • Aug 19, 2013 1:53 PM UTC
Since you data resides in a database you can make use of the min/max XY + clip to search envelop parameters, usually found under parameters>advanced.
This way the users can enter min/max XY coords for the writer to clip.
Hope this helps,
Itay
I'm not sure what the "GP" means. Geo Processing?
If you need to filter features using a geometry specified by user, consider using the SpatialFilter or Clipper. Or else, the BoundsExtractor can be used to get the coordinates of corners of a bounding box surrounding a geometry, the BoundingBoxReplacer or BoundingBoxAccumulator can be used to create a bounding box area.
You have a choice depending on what you want to do.
  Takashi
fmelizard
  • Aug 19, 2013 1:59 PM UTC
correction :
This way the users can enter min/max XY coords for the READER to clip.
jhawks
  • Aug 19, 2013 2:00 PM UTC
GP in this case is Global Position, Lat/Long Clipping. Sorry I wasn't more specific.
  • Aug 19, 2013 2:24 PM UTC
you could accomplish this with a Creator followed by a couple of 2DPointAdders and a LineCloser based on the Lat/Lon published parameters to build the clipping polygon, which you then pass on the the Clipper.
David
