Change attribute based on dublicated id
  • Jun 3, 2019 3:35 PM UTC
  • 68 views
jugoslaviaa
Hi all,
The image you can see the attribute table of my datasets. I would like to change the attribute position based on a logic like this
  • If the position of an object is UNDEFINED, I would like to find an object that has same _id value and then if the object with same _id's position is RIGHT, assign the position value as LEFT.
  • For example, the object with _id_rule 14 has position as UNDEFINED, so i would like the find the other object that has _id 11 (it is common in both object). In my case, It would be the object with _id_rule 10. Then I would like the check the position value of the object with _id_rule 10. If it is RIGHT, I would like to change UNDEFINED value to LEFT for the object with _id_rule 14
I have tried to use combination of tester & sampler but could not figure out so far. Any idea? Thanks in advance.
Best answer by takashi
If I understand the rules correctly, this workflow could work as well.
jugoslaviaa
  • Jun 3, 2019 3:52 PM UTC
I have solved it by using combination of NeigborFinder and Tester =)
  • Jun 4, 2019 12:46 AM UTC
