Cascading writing in FeatureWriter
  • July 18, 2022
  • 26 views
whkarto
Forum|alt.badge.img+14
Hi Community,
does anybody know a way to force FeatureWriter to wait for completion of a writing task of a feature type before the next writing is triggered?
I'm trying to delete features on a database (Oracle Non Spatial) with constraints on the affected tables. So I must enforce a specific delete order. Currently I use a rather complex mechanism with mutiple FeatureWriter transformers in chain and would like to tie them down into one FetureWriter.
If a FeatureWriter could be configured in that way it would also be great to do the action within a single transaction. Is this possible too?
ctredinnick
Forum|alt.badge.img+19
  • July 19, 2022
In the writer there should be a parameter of features per transaction, try setting that to 1 so that each delete is committed before trying the next. The help documentation says this will decrease performance.imageAlternatively, you might be able to use a SQLExecutor, where each feature executes a statement to delete itself from the database.
