I am trying to use a GUID field to update records in an ArcSDE Writer. It seems to work perfectly when using an integer field for the Update Key, but when I use a field with type=guid the update does not go through.
Can you do an UPDATE fme_db_operation using a field of type GUID as the Update Key?
Best answer by nathanatsafe
Different versions of FME treat GUIDs slightly differently, including possibly adding or dropping the surrounding { } characters, which can confuse a writer or a transformer like the ChangeDetector. The behaviour also varies slightly between File GDB and ArcSDE GDB. Close inspection of the attribute before the writer, as @david_r suggested, should reveal discrepancies if this is the root issue. Such an issue can be fixed with an AttributeManager.
