Can you assign a priority when publishing a workspace to FME Server?
  • Feb 22, 2017 8:53 AM UTC
  • 13 replies
  • 156 views
verdoodtdries
Forum|alt.badge.img+23
Hello FME-community,
I want to upload a workspace to FME Server and ensure this workspace always runs with a default priority of 50.
Is there a way to set the default priority when publishing the workspace to FME Server?
OR
Can you change the default priority of workspaces once they are published at FME Server?
I know you can assign a priority when launching a workspace by the FMEServerJobSubmitter transformer, but this is not my intention in this case.
Best answer by david_r
Unfortunately, no, you cannot set a default priority for a workspace. You will have to specify the priority each time the workspace is executed (web interface, scheduler, API, etc).
itay
Forum|alt.badge.img+19
  • Feb 22, 2017 9:15 AM UTC
You can set the priority of the scheduled job via the Web UI under advanced, is that what you mean?
  • Feb 22, 2017 10:13 AM UTC
If you have a published parameter called tm_priority that contains the desired priority, I believe this will be used at run-time. At least, that's what the docs appear to be trying to say (they could be clearer).
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/ReferenceManual/Transformation_Manager_Directives.htm
itay
  • Feb 22, 2017 11:31 AM UTC
The tm_priority tag can be used when triggering the ws via an HTTP call to the server by adding it to the call so for example this (&tm;_priority=10) added to the call will set a priority of 10.
todd_davis
  • Feb 23, 2017 9:07 AM UTC
Yes use tm_priority. As itay says, it has to be part of the http call. So you may need to create a public parameter called tm_priority (maybe alias type so you say high priority = 10, low =200). That parameter won't do anything in the workbench itself but when you run the process it will pass &tm;_priority=10 etc in the http call.
In your case if you always want to to be 50. Just create a choice parameter (as public). Call it tm_priority and set the choice and default value as 50. Its ugly how users always see it, but if you make it a private parameter, it won't pass correctly.
fmelizard
Forum|alt.badge.img+22
  • Feb 23, 2017 9:17 AM UTC
This is a great idea and I would encourage you to add an entry to our Ideas exchange so that others can contribute to it and vote it up!
https://knowledge.safe.com/content/idea/list.html
verdoodtdries
  • Feb 23, 2017 9:18 AM UTC
todd_davis,
Thank you very much for your reply.
If I make it private, it also works for me with FME Server 2016.
  • Feb 23, 2017 9:19 AM UTC
I agree. And also being able to set default tags, timeout, notifications etc would be great.
verdoodtdries
  • Feb 23, 2017 9:21 AM UTC
david_r,
Thank you for your answer. The workaround jonathan proposed worked fine for adding a default priority.
verdoodtdries
  • Feb 23, 2017 9:27 AM UTC
itay,
Thank you for answering. In this way I learned you can assign a priority to a scheduled job. I wanted to assign a priority to a job while uploading a workspace to FME Server. This is possible by creating a published or private parameter "tm_priority" as jonathan proposed.
lau
Forum|alt.badge.img+3
  • Apr 19, 2017 2:48 PM UTC
david_r,
verdoodtdries, do you know if this workaround works in fme server 2015? I tryied but it doesn't seem to work...
verdoodtdries
  • Apr 19, 2017 3:40 PM UTC
lau
I only tested it in FME Server 2016, so I cannot confirm for FME Server 2015.
  • Jun 8, 2017 6:06 PM UTC
Has any of you succeeded using this workaround with FME Server 2017?
