Can you add a feature reader (specifically an Esri Geodatabase file) to a custom transformer?
  • Sep 14, 2017 6:43 PM UTC
  • 5 replies
  • 61 views
fmelizard
Forum|alt.badge.img+22
  • Sep 14, 2017 6:48 PM UTC
Hi @bcrowley10, I did a quick test in 2017.1 and was able to do it. Are you getting any errors or troubles when trying it on your end?
  • Sep 14, 2017 6:50 PM UTC
It's disabled. This is my first stab at creating a custom transformer so I could have done something wrong.
fmelizard
  • Sep 14, 2017 6:59 PM UTC
If you find that after enabling it, you're getting errors please post them here. There might be some configuration things that I can help you out with.
gio
Forum|alt.badge.img+15
  • Sep 15, 2017 1:51 PM UTC
a gdb I assume?
Gdb reader greyed out seems to indicate absent esri lcense.
  • Sep 15, 2017 1:53 PM UTC
Thanks all. I figured it out. I used a FeatureReader within my custom transformer to add the GDB file. I'm testing my transformer now.
