Batch process DGN to GDB
  • May 19, 2016 8:30 AM UTC
  • 67 views
Hi , I'm trying to generate a batch process to convert "n" DGN's to "n" differents GDB's. I know that with the workspaceRunner I could do it , but I don't know how to create different ouputs for any input , Any idea ???.
Thanks in advanced for your help.
Regards !!
zzupljanin
Forum|alt.badge.img+5
  • May 19, 2016 9:06 AM UTC
You could do it if you expose fme_basename attribute in reader and writer, then check Fanout by Dataset (fme_basename) and then batch deploy all dgn's you want. This will write new GDB's named as DGN's.
Hope that will help.
stalknecht
Forum|alt.badge.img+22
  • May 19, 2016 9:19 AM UTC
The trick is to use a single merged feature type for the reader in the workspace that you will use in the workspacerunner. You also can create a published parameter for the writer. Then you can set this parameter in the workspacerunner. A Directory and filepath reader is also handy.
thanks for your answers , I'll try !!! thanks again ...
Thanks janin ... it works OK !! , Stalch I haven't tested your solution , sure is good idea also , I've tested the first that I've seen. Thanks to two !!
