Batch Deploy Read Uniquely Named Excel Sheets
  • Dec 1, 2016 11:21 PM UTC
  • 120 views
notmyname
Hello,
I have hundreds of excel books to read one sheet of (they each have only one sheet) then write the data to a database table. I thought this would be simple using batch deploy, I then realized the excel sheet names are different and in the basic way I set up my batch deploy it expects a specific excel sheet name. Is there any way for FME to simply read any excel sheet in an excel book at run time? All the excel sheets have the same column structure.
To be clear:
Excel book= A xlsx file
Excel Sheet= A tab of a excel file
Thanks
Best answer by itay
Hi @notmyname ( what is your name then?) :) anyway its possible have a look at the attached template.
itay
Forum|alt.badge.img+19
  • Dec 2, 2016 11:16 AM UTC
notmyname
  • Dec 2, 2016 4:58 PM UTC
Awesome, I knew there would be way! I really appreciate it!
