AttributeWriter and DataStreamer
  • Nov 19, 2024 2:49 AM UTC
  • 85 views
peteratqfes
If I’m writing a fme-binary attribute out to jpeg using an AttributeFileWriter is there any way to publish as DataStreamer on FME Flow?
Best answer by david_r
Yes, but you cannot use the AttributeFileWriter. You’ll have to use a regular writer, I recommend using the Data File writer, which lets you write arbitrary binary data:https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/datafile/datafile.htm
Make sure to associate the writer with the streaming service when publishing to Flow.
  • Nov 19, 2024 4:21 PM UTC
peteratqfes
  • Nov 19, 2024 10:25 PM UTC
Perfect. It worked a treat. I must admit I’ve never seen the datafile writer.  So many writers to keep track of….
Thank you.
