Attributes not transferring to writer fgdb
  • Nov 6, 2019 4:12 PM UTC
  • 21 views
reidm35
Hi there.
The Geometry Replacer transformer in this workspace have the correct attributes (end_GRID_ID and start_GRID_ID), but FME is not transferring these over to the writer! Any tips?
@reidm35 We'd have to see the attributes you've defined on the Geodb writer feature type Roads_Final_110619_NTS. Usually attributes don'e show up on the output if there is a slight mismatch in the attribute names. Or possibly you have set the feature type attribute definition to Automatic.
