attribute to parameter
  • Mar 6, 2020 3:14 AM UTC
  • 58 views
Hi
I would like to use a attribute value as a parameter for ather transfomer.
Could you tell me the procedure?
danilo_fme
Forum|alt.badge.img+58
  • Mar 6, 2020 3:44 AM UTC
Hi @bigapplerizzi19
Could you give more detail, please?
If you want to get the value of attribute and change it for a attribute name, I suggest you to use the transformer AttributeExploder:
Thanks in Advance,
Danilo
Hi @bigapplerizzi19
Thanks in Advance,
Danilo
Hi Danilo,
Thank you for your reply.
AttributeExploder geneated a combination of _attr_name and _attr_value.
I woud like to generate a parameter with the value from a _attr_value.
Best Regards,
Tom
