ArcGIS Online Reader Character Limit
  • Feb 3, 2025 8:22 PM UTC
  • 51 views
agrant
Participant
I have an AGOL text field with a limit of 1000, but the reader appears to be cutting off the fields at 255 characters. It appears to be happening in the reader directly, not later on in the translations. Any workarounds on this other than just adding an additional text field, or is this a known issue of the AGOL Connector?
j.botterill
Forum|alt.badge.img+69
  • Feb 4, 2025 3:14 AM UTC
hi agrant,
Are you exposing this text field from AGOLconnector, an fme packaged transformer. Have you tried using a FeatureReader with AGOL format  to the same feature service
According to the FME Hub documentation, you need to be using version 19231 https://hub.safe.com/publishers/safe/packages/esri-agol and the Supported Python Versions: 3.5+ on your machine’s preferred python environment
