AppCrash using API Raster - Clipper
  • Mar 12, 2017 3:14 AM UTC
  • 57 views
danilo_fme
Forum|alt.badge.img+58
Hello Team,
I am try to use Clipper function in Python API for Raster.
When i run my Workspace a crash is happen:
Attached my Workspace.
Thanks in Advance,
  • Mar 12, 2017 5:32 AM UTC
Hi @danilo_inovacao, the FME Objects API doesn't have any capability to read and create an FMERaster object from a raster file path, except a case where you read a raster feature from a file using an FMEUniversalReader object.
If the input feature has a raster geometry, this script works to clip the raster held by the input feature and update (overwrite) the geometry of the feature with the clipped raster.
# PythonCaller Script Example: Clip a Raster
# Assuming that the input feature always has a raster geometry.
import fmeobjects
class FMERasterTools(object):
    def input(self, feature):
        # Clipper's extents.
        # Modify these values appropriately according to the requirement.
        xMin, yMin = -97.6864, 30.3571
        xMax, yMax = -97.6802, 30.3509
        # Retrieve the geometry (FMERaster object) from the input feature.
        raster = feature.getGeometry()
        # Create an FMERasterTools object.
        rasterTools = fmeobjects.FMERasterTools()
        # Clip the original raster by the specified extents.
        # The FMERasterTools.clip() method returns a clipped raster.
        newRaster = rasterTools.clip(xMin, yMin, xMax, yMax, raster)
        # Set the clipped raster to the feature.
        feature.setGeometry(newRaster)
        # Output the feature containing the clipped raster.
        self.pyoutput(feature)
See also the FME Objects Python API Documentation.
<FME 2017 Installation Directory>/fmeobjects/python/apidoc/index.html
danilo_fme
  • Mar 14, 2017 10:51 PM UTC
import fmeobjects
Hi @takashi
  Thans your explatnation and comments inside the code.
The explanation was very powerful with this my Doubt.
