Aggregate attributes from other attributes
  • Apr 12, 2019 10:17 AM UTC
  • 5 replies
  • 195 views
geo-x
Dear FME community.
I try to aggregates lines to columns with same ID like that :
In fact it's an intermediate result what I want, because in final result, I need to have this same aggregation with comparaison of different values (best value is A than B) :
This is a link with a data test :
Tank you for your help.
Best answer by ebygomm
If you only want to keep the 'best' value you can assign a score to the value, sort by this score then use the duplicate filter or a sampler to keep only the ID with the 'best' score
lars_de_vries
Forum|alt.badge.img+10
You could use the GroupBy function on the ID field and a Concatenate on the Value. The other option could be to use two Aggregators placed in serie. The first can group on both ID and Value and the second could just use ID.
Maybe you can use a TestFilter to define the best value, but I cannot Judge the comparison of the values.
Forum|alt.badge.img+54
  • Apr 12, 2019 11:11 AM UTC
  • Apr 12, 2019 1:09 PM UTC
What is the definition of the "best value"? In other words, why is "A" is the best in "A", "B" and "Unknow"?
geo-x
  • Apr 18, 2019 12:28 PM UTC
Dear @takashi in this case it is : B best than A, C best than B etc... it's a particular case
geo-x
  • Apr 24, 2019 12:15 PM UTC
Great answer @egomm, thank you very much !
