Add 'Success' output port to Writers
  • Oct 7, 2026 7:43 PM UTC
  • 88 views
joshsaad
Participant
If possible, it would be great if there was a ‘Success’ output port on Writers (I don’t mean FeatureWriters), so that you can use that to initiate subsequent processes.  I often need to control the order that processes need to run between different datasets.
I tried using FeatureWriters and FeatureReaders, using the ‘Summary’ and ‘Initiator’ ports, which works fine in Workbench, but there’s apparently a bug in Flow when outputting to an ArcGISFeatureService.
  • Oct 8, 2026 8:07 AM UTC
This use case was pretty much the reasoning behind the introduction of the FeatureWriter.
I suspect Safe will not add overlapping functionality to the “old” writers.
desiree_at_safe
Forum|alt.badge.img+24
Hi ​@joshsaad. This is an interesting suggestion! If you haven’t already, I encourage you to click  this link  and submit an idea capturing your product improvement suggestions.
Other FME Community users can upvote ideas, and our product team reviews them for future inclusion in FME.
jazhamilton
Participant
  • Participant
  • Oct 28, 2026 11:43 PM UTC
That’s interesting… What’s the bug exactly? Might be worth putting up a Bug Report instead of a new feature request?
desiree_at_safe
​@jazhamilton , thank you for that! I missed that detail.
If you haven’t yet, if you could please submit a ticket so that our team can look into this further, that would be great!
When submitting your ticket, please provide the following (if available):
- Details about the environment used (e.g. platform and OS version, FME Flow deployment, any other dependencies, etc.)
- Any relevant log files (e.g. translation logs, job logs, fmeserver.log, etc.)
- Any relevant screenshots (e.g. errors, configurations, etc.)
- Please provide a sample of the source data used in your workspace
- The workspace (or sample workspace) that you are encountering issues with. Please be sure to include any required data or custom transformers needed. If, possible please send this as a template (.fmwt).
