Add data column AND populate by sub directory name
  • Apr 4, 2013 2:16 PM UTC
  • 66 views
Hello,
I have a bunch of mapinfo line.tab files that I want to merge together.  Each .tab file is in a seperate sub directory e.g.
/test/one/line.tab
/test/two/line.tab
/test/three/line.tab
I want to add a 'dir' text column to each layer before merging that is populated with the files sub directory name e.g.
line.tab layer in the one directory will have a new column added 'dir' and be populated with value 'one'
line.tab layer in the two directory will have a new column added 'dir' and be populated with value  'two'
...etc
I see that hte AttributeCreator transformer can populate data columns, however I'm unsure how to get the data in the format as stated above.
thank you
Best answer by fmelizard
expose the fme_dataset and use the FilenamePartExtractor.
Hope this helps
fmelizard
Forum|alt.badge.img+22
  • Apr 4, 2013 2:19 PM UTC
Hope this helps
  • Apr 4, 2013 2:20 PM UTC
look at the FilenamePartExtractor, it should help you along.
David
