Add attribute 'Status' during join/merge (i.e. 'joined', 'unjoined_left', 'unjoined_right')
  • Dec 21, 2022 2:22 PM UTC
  • 81 views
townest
Forum|alt.badge.img+4
Greetings,
Do you have a best practice for adding a 'status' attribute populated with the value of the join status such as 'joined', 'unjoined_left', 'unjoined_right'? I can imagine using a 'create attribute' transformer outside of each join transformer port, but that seems heavy on transformers (four total). Let me know if you have a more efficient solution.
Thank you,
Tyler
Workbench 2022.1
Best answer by dustin
If you right click on the output ports, you can add an attribute and set the value as needed. image
dustin
Forum|alt.badge.img+36
  • Dec 21, 2022 2:32 PM UTC
townest
  • Dec 21, 2022 2:52 PM UTC
@dustin​ ,
Good tip. Thx.
Why are my expansion arrows red now?
imageTyler
dustin
  • Dec 21, 2022 2:54 PM UTC
@dustin​ ,
Good tip. Thx.
imageTyler
@townest​ That's an indication that an attribute is being created in the port.
townest
  • Dec 21, 2022 3:02 PM UTC
