Accessing FME Feature Attributes within a Python Caller
  • May 19, 2021 7:25 PM UTC
  • 498 views
crowleyb
Forum|alt.badge.img+4
I am using a pythoncaller to access Zoom API to download unique meeting IDs.
The code is:
import ssl
import http.client
import zipfile
import fme
import fmeobjects
# Template Function interface:
# When using this function, make sure its name is set as the value of
# the 'Class or Function to Process Features' transformer parameter
def processFeature(feature):
  pass
# Template Class Interface:
# When using this class, make sure its name is set as the value of
class FeatureProcessor(object):
  def __init__(self):
    pass
  def input(self,feature):
    self.pyoutput(feature)
  def close(self):
    pass
#Setting User Parameters
MeetingID = "?????????"
conn.request("GET", "/v2/past_meetings/"+ MeetingID +"/instances", headers=headers)
What I would like to do is set MeetingID to feature.getAttribute('SCO_Zoom_Meeting_ID__c') where that is a value returned from a query from my database.
I would appreciate any help. If I just set MeetingID = feature.getAttribute('SCO_Zoom_Meeting_ID__c') it errors saying 'feature' is not defined.
Best answer by hkingsbury
The python caller will either call a class (line 29) or a function (line 17). From what I can guess from your scenario all you'll need is to use the function. This will get called once for each feature that gets passed through the transformer.
In that function is where you write your code, so line 47 onwards needs to be encapsulated in that function.
You will also need to set the transformer to call that function. There is a box at hte top of the window where you enter the function or class name. By default it is the class
hkingsbury
Forum|alt.badge.img+73
  • May 19, 2021 8:10 PM UTC
crowleyb
  • May 19, 2021 9:20 PM UTC
Great! Thank you. That worked @hkingsbury​
