Accents in attributes
- April 4, 2013
- 24 replies
- 377 views
- Safer
- 3725 replies
- April 4, 2013
The string searcher or the string pair replacer are a few options to consider.
- Supporter
- 956 replies
- April 4, 2013
- 8332 replies
- April 4, 2013
here is a more dynamic solution using a PythonCaller. Modify "attribute_list" (line 16, case sensitive) to include the names of the attributes you want to be checked for accents:
import fmeobjects import unicodedata as ud def rmdiacritics(char): ''' Return the base character of char, by "removing" any diacritics like accents or curls and strokes and the like. ''' desc = ud.name(unicode(char)) cutoff = desc.find(' WITH ') if cutoff != -1: desc = desc[:cutoff] return ud.lookup(desc) def removeAccents(feature): attribute_list = ("name", "type", "state") for attrib in feature.getAllAttributeNames(): if attrib in attribute_list: value = feature.getAttribute(attrib) if value: value = unicode(value) new_value = ''.join([rmdiacritics(char) for char in value]) feature.setAttribute(attrib, new_value)
You can also download the code here, in case the forum mangles the indents.
Example values before the PythonCaller:
Attribute(encoded: utf-8): `name' has value `François' Attribute(encoded: utf-8): `state' has value `Tørst' Attribute(encoded: utf-8): `type' has value `Salé'
After the PythonCaller:
Attribute(encoded: utf-16): `name' has value `Francois' Attribute(encoded: utf-16): `state' has value `Torst' Attribute(encoded: utf-16): `type' has value `Sale' David
- 8332 replies
- April 4, 2013
import fmeobjects
if cutoff != -1:
attribute_list = ("name", "type", "state") # Modify as needed
if value:
- Attribute(encoded: utf-8): `name' has value `François'
- Attribute(encoded: utf-8): `state' has value `Tørst'
- Attribute(encoded: utf-8): `type' has value `Salé'
- Attribute(encoded: utf-16): `name' has value `Francois'
- Attribute(encoded: utf-16): `state' has value `Torst'
- Attribute(encoded: utf-16): `type' has value `Sale'
- Author
- 15 replies
- April 4, 2013
THis is exactly what i am looking for. However i am new with python scripts, and still stuck in FME2011 so it looks like this code will work with 2012. Any suggestions on how to implement in 2011?
Thanks!
- 8332 replies
- April 4, 2013
seems like a good opportunity to learn some Python, then :-)
Basically, replace
- "fmeobjects" with "pyfme"
- "getAttribute" with "getUnicodeString"
- "setAttribute" with "setUnicodeString"
Untested, but I think that should be enough to get it running, I hope.
Also, take a look at the pyfme API doc in <fmedir>\\\\fmeobjects\\python\\apidocs\\index.html -- in particular the methods under FMEFeature.
David
- Author
- 15 replies
- April 4, 2013
One last (and probably dumb) question. What symbol is used in the caller?
- 8332 replies
- April 4, 2013
not a dumb question when you're not familiar with the PythonCaller :-)
You should use "removeAccents" for the PythonCaller.
Hint: it's almost always the function ("def ...") that takes a parameter called "feature", which represents each feature object passed into the function. E.g.
def <name of function>(feature):
David
- 1 reply
- April 4, 2013
Source Attribute: Name
Replacement Pairs: É E È E Ë E Ê E Ô O Ç C Â A ï I î I
Result Attributer: Name2
- 8332 replies
- April 4, 2013
I agree, that is the most "native" FME solution, but it assumes that you're able to populate it with all the possible variants. If something isn't caught (like a sudden "Û" in your example), it will simply pass through and result in an error further down the line, where it might not be obvious what happened.
The beauty of the PythonCaller script is that it is a lot more future-proof, although it adds quite a bit of complexity, I must admit...
David
- Author
- 15 replies
- April 5, 2013
- 9 replies
- April 5, 2013
import unicodedata def remove_accents(input_str): nkfd_form = unicodedata.normalize('NFKD', unicode(input_str)) only_ascii = nkfd_form.encode('ASCII', 'ignore') return only_ascii
- 10 replies
- January 27, 2016
import fmeobjects
if cutoff != -1:
if value:
Thanks David, that solution is just awesome! I used it via a Python Caller and it worked perfectly fine!!
Cheers mate!
- 178 replies
- October 5, 2016
I noticed that I regularly kept comming back to this question because of the provided code by @david_r.
I figured there probably are more people using this code so I converted it to a custom transformer:
- 8332 replies
- October 5, 2016
- 4 replies
- October 25, 2018
- 8332 replies
- October 26, 2018
Here's the same code updated for Python 3.6, @jeroenstiers
import fmeobjects
desc = ud.name(char)
if cutoff != -1:
if value:
value = str(value)
- 4 replies
- October 26, 2018
import fmeobjects
if cutoff != -1:
if value:
value = str(value)
- Enthusiast
- 303 replies
- October 26, 2018
Use the StringPairReplacer and paste this string below into the Replacement Pairs parameter.
Create a custom transformer and use it easily in any workbench. I've created the AccentRemover just like that :D
It's only good for french though...
à a À A â a  A ç c Ç C é e É E è e È E ê e Ê E ë e Ë E î i Î I ï i Ï I ô o Ô O ù u Ù U û u Û U ü u Ü U
- 8332 replies
- October 26, 2018
- 8332 replies
- October 26, 2018
- Contributor
- 49 replies
- June 28, 2022
HI David,
The download file no longer appears to available.
I tried the code above up I can't get it to work, and my python isn't strong enough to see where i have gone wrong. It runs but doesn't to remove the accents :(
Here is a screen shot of my python caller
- 8332 replies
- June 29, 2022
HI David,
Try using the StringDiacriticRemover from the FME Hub in stead: https://hub.safe.com/publishers/safe-lab/transformers/stringdiacriticremover
- Contributor
- 49 replies
- June 29, 2022
HI David,
Thanks will do :)
Related Topics
Arris Touchstone CM8200 becomes unresponsive when power goes out and generator comes onicon
Modem - GeneralPotential Help on a SBG6782-ACHicon
Wi-Fi Modems - GeneralMy Surfboard T25 randomly loses its internet connectionicon
Modem - GeneralArris S33 V2 intermittent internet connectionicon
S33 | S34SB8200 Modem will not connect to internet. Need help getting Arris to honor the warranty.icon
SB8200
Helpful Members This Week
- alexbiz
38 votes
- raghavendrans
30 votes
- redgeographics
28 votes
- jackyd
22 votes
- crutledge
20 votes
- hkingsbury
19 votes
- takashi
18 votes
- ebygomm
10 votes
- nielsgerrits
10 votes
- fme_can_do_it
9 votes
Recently Solved Questions
Community Stats
- 31,278
- Posts
- 118,626
- Replies
- 38,868
- Members
Latest FME
Scanning file for viruses.
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
OKThis file cannot be downloaded
Sorry, our virus scanner detected that this file isn't safe to download.
OKCookie policy
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
