Getting lists in PythonCaller
  • September 5, 2017
  • 7 replies
  • 982 views
I am using FME Desktop 2017 and would like to know if there is a way to get a list that I have generated in my FME Workflow, into the PythonCaller, in a similar way to how you use 'getAttribute' function feature.getAttribute(x) to get a normal attribute into the PythonCaller.
Thank you for your help in advance.
Best answer by jdh
For simple and compound lists you can just use
feature.getAttribute('list{}') or feature.getAttribute('list{}.x')
For nested lists you need to loop through the parent list to get the sublists.
jdh
Forum|alt.badge.img+28
  • September 5, 2017
danilo_fme
Forum|alt.badge.img+45
  • September 5, 2017
Hi @aquamarine,
I created a Workspace that show the print values from a List ( _list{}.names ) in Log file using the PythonCaller:
Thanks,
Danilo
  • September 5, 2017
That's exactly what I needed!
Thank you @jdh
  • January 10, 2018
danilo_fme wrote:
Hi @aquamarine,
Thanks,
Danilo
Hi all
I am getting from Excel a column called Name,
after I built lists with Listbuilder ,
but I have an error in my pythoncaller,
please provide some feedback
jdh
  • January 10, 2018
josesauz wrote:
Hi all
If you inspect the features prior to the PythonCaller, does every feature have a value for _list{0}.Name?
You can try adding "if Nombres:" just prior to the for loop, so that there is no python exception if there list doesn't exist.
  • January 11, 2018
Yes, the list has many values , I dont know is I can iterate the object..
@takashi , @david_r , @danilo_fme , @takashi
I am using FME 2016.1
jdh
  • January 11, 2018
There seems to be some white space at the end of the _list{}.Name attribute.
