Your Job has been submitted does not run
  • Feb 7, 2020 9:51 AM UTC
  • 58 views
perry
Hello,
I've updated FME server V2018 to V2019.2.3
Unfortunately nou the scheduling does not run.
There are no scheduled tasks in the que.
If I manually start a job at the server it appears in the que but does not run at all.
Wich services are responsble for the schedular. Do they have to run with SYSTEM?
Or do all the services have to run with SYSTEM?
thanks for your reply
Best answer by perry
Hi David,
I've found this item:
Confirm the paths to the FME Engines are valid by looking in the process monitor configuration
file here:
FME Server 2015 and newer: \\Server\\ processMonitorConfigEngines.txt
The paths to the FME Engines are visible near the end of the file:
I have replaced this file with out backup file. Now the scheduling is recognized en jobs are in the que and running.
I still do not know why or if this is the solution, but I'm glad the scheduling is working.
I will monitor this the next few days. for now thanks.
  • Feb 7, 2020 9:56 AM UTC
When you did the update, did you follow the manual and also make sure to not keep the old internal FME Server database?
perry
  • Feb 7, 2020 9:58 AM UTC
yes, we followed the instructions server V2019.
  • Feb 7, 2020 10:10 AM UTC
If the server works with the services running as local system, but not as the dedicated service account, I would assume that the service account doesn't have the necessary rights.
perry
  • Feb 7, 2020 11:02 AM UTC
Hi David,
file here:
