Where does FME Desktop Licensing Assistant create the license files?
  • Nov 10, 2016 6:50 PM UTC
  • 1048 views
fmelizard
Forum|alt.badge.img+22
What is the location of the license files created by FME Desktop Licensing Assistant?
And how can I ensure that users without Admin privileges will not have to run this application too?
Keywords: mac license location fixed licence location
rylanatsafe
Forum|alt.badge.img+14
FME for Windows looks for licenses in the following three places:
  • C:\\ProgramData\\Safe Software\\FME\\Licenses [This is the default location.]
  • <fme-install-folder>/licenses
  • C:\\users\\<user>\\Documents\\FME\\Licenses
If licensing FME for the first time, this may require a user with Admin privileges to run the Licensing Assistant.
If you manually place the license files in any of the locations (placing in the <fme-install-folder> will require admin privileges), then you should not have to run the FME Desktop Licensing Assistant.
If you place the license files in either the first or second location, then a user without Admin privileges should not have to run the FME Desktop Licensing Assistant.
FME for Linux (Ubuntu 14.04) places the files in /home/<USER>/.fme/Licenses
Note: License files can also be stored in <fme-install-folder>/licenses
FME for macOS stores the licenses in /Users/<username>/Library/Application Support/FME/Licenses/
[Edited 2021-March-11 to add some clarification regarding the current default location and running the Licensing Assistant. The original text has been left for reference with strikethrough.]
