What is the process to upgrade FME Server to 2017
  • Apr 12, 2017 2:40 PM UTC
  • 56 views
Looks like it is asking to uninstall the old install. Will that remove all the current data and processes?
  • Apr 12, 2017 2:55 PM UTC
Have a look in the documentation:
http://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Upgrading.htm
Basically:
  1. Backup of existing instance using FME Server GUI
  2. Uninstall old
  3. Install new
  4. Restore backup
erik_jan
Forum|alt.badge.img+26
  • Apr 12, 2017 2:58 PM UTC
In my experience the process described by @david_r works fine.
The only issue might be, that you have to re-create all users if you are using Active Directory for security.
itay
Forum|alt.badge.img+19
  • Apr 12, 2017 5:24 PM UTC
the backup will contain your repositories and workspaces if that is what you mean.
