What does all the lines in the safe.lic file actually mean?
  • January 15, 2024
  • 202 views
gabriel_hirsch
Forum|alt.badge.img+15
Perhaps just of curiosity, I would like to know what all the lines in the safe.lic license file actually mean. Not an answer like "they are needed" but more information why they are needed and what they correspond to.
FEATURE FME (this might be the main license)
FEATURE FME_GUI
FEATURE national
FEATURE basic_raster
FEATURE segy_reading
FEATURE segy_writing
FEATURE smallworld (this is the license level)
FEATURE fmeobjects_reproject
FEATURE ssis_extension
FEATURE spatialbiz
I've heard during my years as a FME expert that some of these lines correspond to "old licensing levels" or similar but now with FME Form, is that really true?
Best answer by mark2atsafe
Yes, as @david_r noted, those are old license options that we don't use any longer. For example, "basic_raster" might have been a way to exclude raster from BASE licenses. SegY is an oil/exploration format. SSIS and Spatialbiz are two Smallworld options. I assume that "fmeobjects_reproject" allows the reprojection functionality inside FME Objects, and I suspect "FME_GUI" was when we first introduced Workbench, which would be a long time ago. I've no idea what "national" means.
Those lines might just be in there for backwards compatibility. They don't really hurt being there and I don't know what would happen if they were removed!
  • January 15, 2024
I'm also suspecting legacy licenses and/or third-party extensions (the recently deprecated MapTextLabeller comes to mind), but I'm equally curious as to the "official" story 🙂
@mark2atsafe​ Do you have the inside scoop on this?
mark2atsafe
Forum|alt.badge.img+59
  • January 15, 2024
