We have just upgraded to build 22789 and the install of fme desktop to one of the machines seemed to succeed but when I try and launch desktop it crashes
  • Mar 7, 2023 9:20 AM UTC
  • 89 views
I am struggling with install of FME desktop....
This is the detail from the event log.
Machine is windows server 2019.
Faulting application name: fmeworkbench.exe, version: 2022.7.45.22789, time stamp: 0x63d9e992
Faulting module name: Qt6WebEngineCore_fme.dll, version: 6.2.4.0, time stamp: 0x625ef5dc
Exception code: 0x80000003
Fault offset: 0x0000000002645d96
Faulting process id: 0x37bc
Faulting application start time: 0x01d950d3b739183b
Faulting application path: C:\\Program Files\\FME\\fmeworkbench.exe
Faulting module path: C:\\Program Files\\FME\\Qt6WebEngineCore_fme.dll
Report Id: 9d532fef-92d3-429e-b884-fb15a1e27e8a
Faulting package full name:
Faulting package-relative application ID:
We have successfully installed it on another windows 2019 server and it does run
FME is also running successfully with build 22789 in the machine where desktop doesn't work.
  • Mar 8, 2023 3:22 PM UTC
A second reinstall seems to have resolved the problem, not sure why though.
