We have configured/upgraded FME Server from 2019 to 2021.2.4. As per our prior discussion we can use current FME server license , but while configuring existing licenses we are getting error as below:
  • Mar 24, 2022 2:40 PM UTC
  • 50 views
The FME Server license doesn't recognize the current machine because it is limited to one or more specific machines.Use FME Sever on a machine for which it is licensed.
Kindly assist us same.
Best answer by david_r
The FME Server license file is bound to the specific machine from which it was requested. If you want to license FME Server on a different machine, you'll have to regenerate the license request from that machine.
See also https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Request_and_Install_a_License-Express-Windows.htm
  • Mar 24, 2022 3:29 PM UTC
