Upgrading from FME FLOW from 2024.0.3 to FME FLOW 2024.2.1.
  • January 29, 2025
  • 50 views
vivekdey451
Hello FME Community users,
I am trying to upgrade FME FLow from 2024.0.3 to 2024.2.1. I looked into this article
https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Upgrade-in-Place-Same-Machine.htm
Just wondering if there is a better compared to install/uninstall as mentioned above. Such as done on ESRI side.
Best answer by hkingsbury
Unfortunately you do need to completely uninstall FME Flow from a machine before installing a new version. There is no method of incrementally upgrading.
Make sure you create a backup and make a copy of your encryption key before performing the uninstall!
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
hkingsbury
Forum|alt.badge.img+55
  • January 29, 2025
vivekdey451
  • January 30, 2025
Thanks for the confirmation.
