Truncate or drop and create?
  • Feb 14, 2025 6:08 PM UTC
  • 301 views
smclaugh1
Forum|alt.badge.img+8
If I’m going to truncating and overwriting a hosted feature service every day in ArcGIS Enterprise is it better to truncate, or drop and create?
crutledge
Forum|alt.badge.img+55
  • Feb 15, 2025 5:21 PM UTC
I have used both. Truncate will preserve the ESRI ItemID and as a result any applications that reference your Hosted Feature Layer will keep functioning fine. I believe if you were to drop and create you would end up with a new ItemID and then break whatever references the service (maps, apps, views etc). Hope that helps!
hkingsbury
Forum|alt.badge.img+73
  • Feb 16, 2025 11:02 PM UTC
In your case, i’d leave it as a truncate. A drop and create will also go through and recreate schema.
