The Path variable seems to be ok - the Client can connect to the Oracle database - Some issue between the Application and version of Oracle installed.
Transalation using fme desktop 2012 on Windows 7 oracle client 11.2.0 x64
Transalation using Fme desktop 2012 fails error - Oracle client libraries could not be loaded. Ensure the client is installed and properly configured. Check the System path Environment Varialble.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
