Segmentation fault - FME Worbench on Linux
  • Mar 20, 2014 4:07 PM UTC
  • 138 views
Hi, I have installed FME Desktop onLinux (Technical Preview), unforunatelly when I try to start Workbench I get the following message: Segmentation fault
Did anyone of you have similar problem, is it something wrong with Linux configuration? fmedatainspector seems to work fine.
hasant1973
Forum|alt.badge.img+3
  • Sep 15, 2025 11:51 AM UTC
I have the same problem with fme cli, workflow A works on the same machine but workflow B returns immediately the error.
desiree_at_safe
Forum|alt.badge.img+25
Hi ​@hasant1973! I noticed you commented on an older post. I would create a new thread with a link to this post as a reference to the problem you are facing. This would get more visibility as comments like these often get lost.
