Lost "Favourite Workspaces" after completion of FME Server upgrade - FME Serve engine detection issue
  • Nov 28, 2019 11:37 AM UTC
  • 82 views
sameer
Forum|alt.badge.img+23
Hello,
I've recently upgraded FME Server to the latest build (19801) because of the recently flagged security vulnerability involving Active Directory.
Followed the required steps, i.e Backup / Restore Test, then Uninstall current Version / Install latest Version / restore backup. All went well.
1) However my "Favorite Workspaces" have disappeared but not the end of the world.
2) I'm still having to re-adjust the amount of FME engine required after server reboot (on going) which involves "Refreshing" of FME Server licence. I only have one for now but FME Server detects 2 after server reboot.
Are points 1) & 2) known issues?
Thanks
Sameer
  • Nov 29, 2019 8:14 AM UTC
Number 1 sounds like it might be a bug/omission on the backup/restore functionality. I'd forward it to Safe support.
No idea about number 2, however, I've never had that issue.
sameer
  • Nov 29, 2019 10:11 AM UTC
@david_r Issue No 2 occurred when FME server was first installed. I was made aware by the contracted FME Server consultant that it does happen.
Is this log somewhere so I can share my findings?
  • Nov 29, 2019 10:14 AM UTC
You can contact Safe support here: https://www.safe.com/support/report-a-problem/
