Licensing FME Server Fails
  • Apr 30, 2019 9:53 PM UTC
  • 123 views
fmelizard
Forum|alt.badge.img+22
I'm trying to licence a new installation of FME Server, but I keep getting these errors if I upload or request a new licence respectively. I'm sure my license file is valid. Whats going on?
The license file failed to upload
License request did not succeed
Best answer by richardatsafe
In most cases these errors are caused by a permissions issue. If you have a distributed installation or a FME Server Systems Share that is on a network drive you will most likely have to change the Log On As account running the FME Server services to an account with proper permissions.
https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Running_System_Services_Under_Different_Accounts.htm?
richardatsafe
Forum|alt.badge.img+11
