license server don't work with 2016
  • Aug 8, 2017 3:12 PM UTC
  • 41 views
Hello,
We want to transfer the license server to a new one.
Now FME 2104 2015 and 2017 are working fine but the FME 2016 have an license issue.
What could be the problem ??
Greetings Arie Buijs
  • Aug 8, 2017 3:14 PM UTC
This is a good starting point:
https://knowledge.safe.com/articles/543/floating-license-troubleshooting.html
Generally speaking there is no good reason why FME 2016 shouldn't work in your case. I suspect a connection problem (firewall, etc).
Forum|alt.badge.img+63
In addition to what @david_r said, if the problems persist I'd recommend getting in touch with either your VAR's or Safe's support team. The structure of the floating license file has changed a bit a while ago, but I wouldn't expect that only FME 2016 should fail to get a license.
