JobHistoryStatisticsGathering problem
  • Jun 20, 2018 8:46 AM UTC
  • 115 views
Hi, I'm trying to run the JobHistoryStatisticsGathering workspace on FME Server and I'm having some trouble with security. When I try to run the workspace I get the following errors in the log:
JobHistoryReader_HTTPCaller_2(HTTPFactory): HTTP/FTP transfer error: 'SSL connect error'
JobHistoryReader_HTTPCaller_2(HTTPFactory): Please ensure that your network connection is properly set up
JobHistoryReader_HTTPCaller_2(HTTPFactory): No proxy settings have been entered. If you require a proxy to access external URLs, please ensure the appropriate information has been entered
I enabled HTTPS when installing the server, so the URL the workspace is trying to initially connect to is HTTPS://{servername}:80/fmetoken/generate
I've modified the HTTP_Caller client parameters in the JobHistoryReader component to turn off SSL certificate validation as per the tip in
https://knowledge.safe.com/articles/55053/fme-server-troubleshooting-fme-server-dashboards.html
but it still isn't working. Trying to navigate to the fmetoken/generate URL in IE gives the following page:
This page canrsquo;t be displayed
Turn on TLS 1.0, TLS 1.1 and TLS 1.2 in Advanced settings and try connecting to https://pri-fme-01.surreycc.local:80 again. If this error persists, it is possible that this site uses an unsupported protocol or cipher suite such as RC4 (link for the details), which is not considered secure. Please contact your site administrator
Does anyone have any ideas what could be wrong? I'm guessing it's to do with SSL/TLS configuration on the server but not sure what is required to make the connection work
Thanks
Adam
Incidentally, I used IISCrypto to disable some protocols and ciphers, in order to meet our corporate security standards. If someone know which ones need to be enabled in order to make the web service work, I can go back to the security team to request that we enable them
I can provide a list of what's enabled/disabled if that would help
Thanks
Adam
