Is there a way to change generated FME engine result zipped file name?
panda
Forum|alt.badge.img+20
I’m wondering is there a way to add like datetime stamps to the engine result zipped file name? I know this need to be unique but would be nice to add datetime stamps to it while have it remain unique.
Best answer by j.botterill
HI Panda, I suspect you might need to use a scripted parameter that returns the server resource file path. Something like this to include the FME_JOB_ID folders as per this article
 Have you published the workspace with the DataDownload service here? The zipped result will likely include writer/featurewriter name
ttps://docs.safe.com/fme/2025.0/html/FME-Form-Documentation/FME-Form/Workbench/fmeflow-register-workspace.htm
j.botterill
Forum|alt.badge.img+48
  • March 28, 2025
panda
  • March 28, 2025
Thank you for your reply!! I’ll try this!
