Is FME Server 2015 is upgradable to FME Server 2016
  • Aug 3, 2017 3:03 PM UTC
  • 63 views
How can upgrade the license of 2015 FME Server to FME server 2016. In FME server 2016 there is no licensing assistant to use the license from floating server.
Best answer by catatsafe
Hi @subinks238,
When upgrading to FME Server 2016+ you will need to request a new license, as we no longer use FlexLM. All licensing is now done from within the Server Web Interface > Engines and Licensing page.
https://knowledge.safe.com/articles/22776/fme-server-licensing-walk-through.html
https://knowledge.safe.com/articles/33925/moving-to-the-fme-server-2016-licensing-model.html
Cheers,
Cat
  • Aug 3, 2017 3:22 PM UTC
Hi @subinks238,
Cheers,
Cat
