httpcaller replace httpfeatcher - Proxy setting missing
  • Jul 22, 2016 12:04 AM UTC
  • 68 views
rudy_v
I've used the httpfetcher in my 2014 WB, and it had proxy setting, and the script worked perfectly through the proxy.
When i upgraded it with the new htppcaller in 2016.1, that option has disappeared and script no longer working.
We have a few of these, and none seems to work
please suggest a way with proxy (don't want to use the fme option, because it is not a good way of implementing proxy)
I think FME should be more proxy aware
Rudy
rudy_v
  • Jul 22, 2016 12:23 AM UTC
Ok - got it to work, it seems 2016.1 the system proxy option is working. It seems to gave problem in 2014 version
still need to work out to make it work on FME Server
  • Aug 10, 2016 4:13 AM UTC
HTTPCaller needs proxy setting, because sometimes you need to specify a proxy just for a workspace, not system-wide.
mark2atsafe
Forum|alt.badge.img+59
I imagine we made it a system setting because then you don't need to set it multiple times within the same workspace. But I see your point. If you think it's a big issue for you, please do contact our support team (safe.com/support) and make the suggestion, or post it as an idea on this site (Click the New Idea button above-right).
