How to get transformer 'Emailer' installed?
  • Aug 14, 2023 1:03 PM UTC
  • 158 views
Installing FME 2023.0.1 doens't deliver the possibility to download and install transformers such as 'Emailer'. FME seems not to find the (correct) interpreter.
See long error message below:
An error occurred while installing Python package with 'pip install --force-reinstall --no-deps --no-index --find-links C:\\Users\\YairLevy.AzureAD\\AppData\\Roaming\\Safe Software\\FME\\Packages\\23332-win64\\PackageFiles\\safe.emailer\\python --target C:\\Users\\YairLevy.AzureAD\\AppData\\Roaming\\Safe Software\\FME\\Packages\\23332-win64\\python\\safe.emailer --upgrade --no-compile fme-emailer' : INFORM: The workspace does not contain user Python. FME will attempt to use a Python 3.11+ interpreter
INFORM: Using Python interpreter from `C:\\Program Files\\FME\\fmepython311\\python311.dll' with PYTHONHOME `C:\\Program Files\\FME\\fmepython311'
INFORM: Python version 3.11 loaded successfully
Traceback (most recent call last):
 File "<frozen runpy>", line 198, in _run_module_as_main
 File "<frozen runpy>", line 88, in _run_code
 File "C:\\Program Files\\FME\\python\\pip\\__main__.py", line 29, in <module>
  from pip._internal.cli.main import main as _main
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\cli\\main.py", line 9, in <module>
  from pip._internal.cli.autocompletion import autocomplete
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\cli\\autocompletion.py", line 10, in <module>
  from pip._internal.cli.main_parser import create_main_parser
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\cli\\main_parser.py", line 9, in <module>
  from pip._internal.build_env import get_runnable_pip
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\build_env.py", line 19, in <module>
  from pip._internal.cli.spinners import open_spinner
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\cli\\spinners.py", line 9, in <module>
  from pip._internal.utils.logging import get_indentation
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\utils\\logging.py", line 29, in <module>
  from pip._internal.utils.misc import ensure_dir
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\utils\\misc.py", line 43, in <module>
  from pip._internal.locations import get_major_minor_version
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\locations\\__init__.py", line 14, in <module>
  from . import _sysconfig
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\locations\\_sysconfig.py", line 11, in <module>
  from .base import change_root, get_major_minor_version, is_osx_framework
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\locations\\base.py", line 9, in <module>
  from pip._internal.utils import appdirs
 File "C:\\Program Files\\FME\\python\\pip\\_internal\\utils\\appdirs.py", line 13, in <module>
  from pip._vendor import platformdirs as _appdirs
 File "C:\\Program Files\\FME\\python\\pip\\_vendor\\platformdirs\\__init__.py", line 44, in <module>
  PlatformDirs = _set_platform_dir_class() #: Currently active platform
 File "C:\\Program Files\\FME\\python\\pip\\_vendor\\platformdirs\\__init__.py", line 23, in _set_platform_dir_class
  from pip._vendor.platformdirs.windows import Windows as Result
 File "C:\\Program Files\\FME\\python\\pip\\_vendor\\platformdirs\\windows.py", line 3, in <module>
  import ctypes
 File "ctypes\\__init__.py", line 8, in <module>
ImportError: DLL load failed while importing _ctypes: The specified module could not be found.
Error in running the Python command 'python %0'
Program Terminating
Translation FAILED.
. An error occurred while installing package 'C:\\Users\\YairLevy.AzureAD\\AppData\\Roaming\\Safe Software\\FME\\Packages\\23332-win64\\PackageFiles\\safe.emailer'
(Re)installing FME doesn't help.
Any idea?
Thank you.
evieatsafe
Forum|alt.badge.img+28
  • Aug 14, 2023 6:29 PM UTC
Hi @yair.levy​ sorry you've encountered this issue! The email package can be found here if you would like to reinstall the package: https://hub.safe.com/publishers/safe/packages/emailer
Maybe a different version would fix the issue, I'm not quite sure. If the issue persists after reinstalling the package from the Hub, I would suggest creating a case with us here: https://community.safe.com/s/submit-case
