How to fix when BackupConfiguration.fmw fails to retrieve the Backup?
  • Dec 2, 2024 6:47 PM UTC
  • 6 replies
  • 377 views
jaygrg111_
Forum|alt.badge.img+9
Hi everybody,
Our BackupConfiguration.fmw has been failing lately. Based on the following post, I created new schedule on Flow but still having issues.
With the new schedule, I am having the attached error. However, gisadmin does have a fmesuperuser role.
Any insights is highly appreciated.
Thanks in advance!
hkingsbury
Forum|alt.badge.img+73
  • Dec 2, 2024 11:51 PM UTC
Have a look at the logs and see if you get more details.
But based on that message, as a 401 http response is authentication related, something is not right with the account either:
  • Wrong account name
  • wrong account password
  • or wrong access rights.
If you login to the Flow interface with that account, can you manually trigger a backup? That would help rule out FME access rights
jaygrg111_
  • Dec 3, 2024 5:23 PM UTC
​@hkingsbury Thank you for your suggestion. I did check out the logs. If I run it manually, then I get the following error. I checked the username and password, even entered them manually on FME flow, but still give the same error. Any suggestion is highly appreciated.
Thanks
hkingsbury
  • Dec 9, 2024 6:56 PM UTC
Is the user part of the correct group? As per the error message it needs to be a superuser
jaygrg111_
  • Dec 9, 2024 9:08 PM UTC
HI ​@hkingsbury ,
Yes it is has the following role:-
paul.grimes
Participant
  • Participant
  • Dec 22, 2025 8:44 AM UTC
Hi Guys,
I currently have the same issue..     did you ever resolve this ?  any help appreciated
Paulg
j.botterill
Forum|alt.badge.img+69
  • Dec 22, 2025 9:16 AM UTC
Yes the scheduled run of Backup Configuration workspace has to be owned/run by admin (superuser) credentials
