How an IP change may affect FME Flow installation
  • Aug 11, 2023 7:53 AM UTC
  • 140 views
lau
Forum|alt.badge.img+3
Hello,
My IT team wishes to change the IP address of the machine hosting FME Flow. The domain name remains the same. The DNS resolution will be adjusted to point to this new IP. Are there any impacts on the proper functioning of FME Flow?
Thank you in advance for your responses.
Lau
  • Aug 11, 2023 8:10 AM UTC
Unless you specified the IP address rather than the hostname during the FME installation, it should be fine. You'll probably have to reboot the machine after the IP address change, however.
Forum|alt.badge.img+63
In addition to that, any whitelisting in other services that's done based on the ip address will have to be changed as well.
