Hot to run workbench with python with a specific FME version
  • Aug 5, 2022 2:10 PM UTC
  • 117 views
so_much_more
I have two fme versions installed, 32 and 64-bit. I need to run my workbench in 32-bit but the default version is 64.
How can i adjust for this when i run the workbench using python. Currently it fails silently with "Failure running workspace" and i am guessing the version is the issue. Any advice?
I am running the workbench the fmeobjects
The coda I am running is almost an exact copy of this article
https://community.safe.com/s/article/run-an-fme-workspace-from-python-using-fmeworkspac
dustin
Forum|alt.badge.img+36
  • Aug 5, 2022 2:35 PM UTC
Do you mind posting your python code as it is now?
so_much_more
  • Aug 9, 2022 7:08 AM UTC
For sure, i edited my question. I am using the example found the article.
