Having trouble installing FME Desktop
  • Jun 6, 2016 3:22 PM UTC
  • 103 views
Installation of fme-desktop-b16494-win-x64.msi ended prematurely.
Logging states:
MSI (c) (AC:40) [14:57:23:216]: Doing action: MSIFILENAMESCRIPT
Action 14:57:23: MSIFILENAMESCRIPT.
Action start 14:57:23: MSIFILENAMESCRIPT.
MSI (c) (AC:08) [14:57:23:232]: Cloaking enabled.
MSI (c) (AC:08) [14:57:23:232]: Attempting to enable all disabled privileges before calling Install on server
MSI (c) (AC:08) [14:57:23:232]: Connected to service for CA interface.
MSI (c) (AC:6C) [14:57:23:279]: Failed to marshal script action.
Action ended 14:57:23: MSIFILENAMESCRIPT. Return value 3.
MSI (c) (AC:40) [14:57:23:279]: Doing action: FatalError
Action 14:57:23: FatalError.
Action start 14:57:23: FatalError.
Best answer by lenaatsafe
Hi @edwindaems
this question probably needs to be submitted as a support request via https://support.safe.com/knowledgeSubmitCase
I've asked one of our developers who is working on installers to take a look at your log. Let me share his thoughts/suggestions with you:
  • This error is caused by the VBScript custom action failing to run due to some corruption on the OS.  This post here: http://www.advancedinstaller.com/forums/viewtopic.php?t=20115 explains that it is likely due to a corrupted registration of OLEAUT32.dll.  They recommend trying to register oleaut32.dll.  The relevant commands should be:
regsvr32 /u oleaut32.dll
regsvr32 oleaut32.dll
If the problem persists, please submit a support request and we will do further investigation.
mygis
Forum|alt.badge.img+14
  • Jun 6, 2016 11:28 PM UTC
Hi @edwindaems,
1. Could you please let us know the OS you are using?
2. Do you have administrative rights?
3. Have you tried re-downloading the installer? Perhaps it has been corrupted when downloading.
Cheers,
  • Jun 7, 2016 9:35 PM UTC
Hi @edwindaems
