FMEServerJobSubmitter doesn’t work on FME Server 2014
  • Feb 3, 2014 2:17 PM UTC
  • 20 views
I want to run multiple workspaces in a row on FME Server.
I found this example (http://fmepedia.safe.com/articles/How_To/FME-Server-Workflow-Management) and wanted to test it on our FME Server. But it doesn’t work. The child process always starts with the default parameters. It appears that the FMEServerJobSubmitter doesn’t send the parameter to the child process.
Has everyone experience whit the FMEServerJobSubmitter?
I run FME Server 2014 build 14234 64bit on Windows Server 2012 R2.
Thomas
  • Feb 4, 2014 10:26 AM UTC
Hi Thomas
Yes you are quite right there is an issue with FMEServerJobSubmitter in the release of FME Server 2014 as you descirbed. This is fixed already for FME Workbench 2014 SP1.  If you need this right away you can download a "beta" of SP1 here:
http://www.safe.com/support/support-resources/fme-downloads/beta/
Look for Build Build 14239 or later
Hope this helps
