FME Server Upgrade - Trial License
  • Mar 18, 2020 5:50 PM UTC
  • 138 views
jiriteach
Participant
Hi - I wanted to find out if a trial license will be lost if FME Server is upgraded?
Is an uninstall/re-install and then restore config backup.
Will this loose the trial license? If so - how does one continue the trial?
e.g. FME Server 2020 installed and wanted to upgrade to 2020.0.01 which I see was just released.
Thanks
Best answer by catatsafe
Hi @jiriteach,
You will have to re-license FME Server if you upgrade, however it doesn't count as a new trial as long as you are within your trial period. Just use the request a license form in the web interface once you have installed the new version. (Don't forget to back up your current installation if you want to keep your settings. )
Cheers,
Cat
  • Mar 18, 2020 5:59 PM UTC
Hi @jiriteach,
Cheers,
Cat
jiriteach
Participant
  • Participant
  • Mar 18, 2020 6:33 PM UTC
Awesome - Thanks
