FME Server - Unable to open log file
  • Oct 31, 2019 3:03 PM UTC
  • 9 replies
  • 538 views
rudacsmap
Forum|alt.badge.img+8
Hello,
we have problem with FME Server - it is unable to open log file, so every job ends with immediate crash after 1 second. The error message is: Unable to open log file `/opt/fmeserver/resources/logs/engine/current/jobs/job_11.log'
The folder „jobs“ exists in this location and is empty. FME Server is able to write there - has sufficient rights. The folder „jobs“ was automatically created when the first job was run - time of creation is the same. So if FME Server created this folder, I suppose it has enough rights to write there.
The configuration is this:
FME Server 2019.1.3 Build 19642 connected to Active Directory with last security patch installed (*.jar file copied in dedicated folder and restart of the server)
OS - Linux 64-bit Debian 9.11
FME Server was upgraded from version 2018.1 on the same machine. Before upgrade it was working ok. After the upgrade every workspace crashes on this logfile error.
Where can be the problem? Is there any other solution than install FME Server on the clean machine?
Forum|alt.badge.img+63
It could be related to low disk space, triggering aggressive cleanup tasks. Could you doublecheck that?
rudacsmap
  • Oct 31, 2019 3:39 PM UTC
Hello, thank you for your response. Yes we checked that - I forgot to write it down here. There is enough space and also the critical cleanup is set up to check disk every 5 minutes and every translation crashes in first second. So I think it is not the reason.
mark2atsafe
Forum|alt.badge.img+59
I see you registered a case with our support team. That's good. I think this is the sort of error message we should look into immediately. I searched through our systems and I see no report of this error message before, so whatever the cause it looks like it is unique.
Does this happen on the workspaces installed with Server? For example the ones under the Samples repository. Or is it only on workspaces that you've published to the Server?
rudacsmap
  • Nov 1, 2019 7:17 AM UTC
Hi Mark, it is happening both on our own workspaces and also on Samples installed with Fme Server.
rudacsmap
  • Nov 1, 2019 1:31 PM UTC
Here are some screenshots from the web UI - workspace austinDownload:
Error in Result Data is the same:
philippeb
Forum|alt.badge.img+23
  • Nov 1, 2019 1:34 PM UTC
Hey I had the same problem! It resolved (for a reason I can't explain) when I add the log parameter into my FME Desktop before publishing. Now everything is OK.
rudacsmap
  • Nov 1, 2019 3:14 PM UTC
Hello, I think that this works in FME Desktop. But I think it has no influence on how the workspace works on FME Server.
mark2atsafe
OK, I was wondering if there was something in the workspaces causing a log location override, but that doesn't seem to be the case. I think we'll have to wait for the support experts to get back to you. They'll probably know more about it than I. But it's hard to see beyond a permissions issue.
rudacsmap
  • Nov 5, 2019 10:10 AM UTC
The problem was in priviliges. The owner of the "jobs" folder was "root" instead of "fmeserver". After changing this the server works fine now. But we do not know what caused this confusion in priviliges. Probably the upgrade.
Thanks to the Safe support team!
