FME Server not able to access ArcPro
  • Jul 7, 2021 10:46 PM UTC
  • 213 views
mark_zl
2021-7-8 08:39:28 | Unable to perform any licensing related tasks. Please check your Esri ArcGIS Compatibility setting. This 64-bit version of FME requires 64-bit Background Geoprocessing, ArcGIS Pro or ArcGIS Server. Refer to this this article http://fme.ly/qua for more details
2021-7-8 08:39:28 | A fatal error has occurred. Check the logfile above for details
When I run a workspace on FME server I get the error above. When It is run locally on FME Desktop it works.
I Read the help on: https://community.safe.com/s/article/geodatabase-formats-missing-greyed-out-or-have-unm
And have installed ArcPro, but now we are getting an error
48	2021-7-8 10:44:59 | Opening the Esri Geodatabase reader
49 2021-7-8 10:45:00 | The ArcObjects license 'Advanced' is being selected from the ESRILicenseInfo ArcObjects call
50 2021-7-8 10:45:00 | The Esri Product license used by this machine does not include licenses for the 'Advanced' licensing level
51 2021-7-8 10:45:00 | Unable to perform any licensing related tasks. Please check your Esri ArcGIS Compatibility setting. This 64-bit version of FME requires 64-bit Background Geoprocessing, ArcGIS Pro or ArcGIS Server. Refer to this this article http://fme.ly/qua for more details
52 2021-7-8 10:45:00 | A fatal error has occurred. Check the logfile above for details
 I checked the ESRI compatibility
We are running ArcPro 2.7 with FME Server 2021.0.1
https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
ArcGIS Pro 2.7.x    FME 2020.2.2 or higher 64 bit only
gazza
  • Jul 8, 2021 2:06 AM UTC
Are the FME Server engines running under the same user account that ArcPro was installed by and licensed for? See https://community.safe.com/s/article/Using-ArcGIS-Pro-with-FME-Server#useracount
mark_zl
  • Jul 13, 2021 11:25 PM UTC
Thanks gazza,
What we did, was add a new user and and gave the user an arcpro licence, plus the steps below:
To Run the FME Server System Services Under Different Accounts
  1. (FME Server Engines service only) If your FME Engines are installed separately from the FME Server Core (Adding FME Engines on a Separate Machine), you may need to update the user account that runs the FME Engines to provide read/write access to the FME Server System Share and FME Server installation directory. Ensure that account has the necessary permissions on the FME Server Core and FME Server Database machines. For more information, see Running the FME Engines Under a Different Account.
  2. Open the Windows Services:
Select Start > Control Panel > Administrative Tools > Services.
Or
Run services.msc.
  1. In the Services list, right-click FME Server Application Server, FME Server Core, or FME Server Engines, and select Properties.
Note: The FME Server Core service is dependent on the FME Server Database service, which must remain under the Local System account.
  1. In the Properties dialog, click the Log On tab.
  2. Select This account, and specify a user account and password that provides permissions to the FME Server System Share and FME Server installation directory. If you are updating the FME Server Engines account, make sure the account corresponds to the user you specified in Step 1.
  3. If Cross-Origin Resource Sharing settings have been updated, and you are updating the FME Server Engines account, grant Write permissions on file cors.properties to the user you specified in Step 1. This file is located in the \\localization\\clients folder of the FME Server System Share. For more information, see Directory and Account Permissions. (You must have direct access to this file; it is not available from the Resources page of the Web User Interface.)
  4. Click OK.
  5. Restart the FME Server System Services you updated.
