FME Server Licensing
  • Mar 7, 2016 7:25 AM UTC
  • 69 views
I am facing an issue in licensing FME Server. I wana know that whether the licensed file is .txt or like fme work bench license file .fmelic ?
  • Mar 7, 2016 7:42 AM UTC
Hi, you can start the licensing procedure from the "Request License" button. See also this article: FME Server Licensing Walk-Through
geosander
Forum|alt.badge.img+7
  • Mar 7, 2016 7:45 AM UTC
It should be an *.fmelic file, but note that the licensing changed in 2016 (it no longer uses FlexLM), so if your trying to attach your old license file to Server, this probably won't work. You need to request a new one (see Takashi's link below).
mygis
Forum|alt.badge.img+14
  • Mar 7, 2016 8:51 AM UTC
Hi Faran, just in case, here is a great video to get you going.
https://www.youtube.com/watch?v=CCfg3hHYPyw
